| I'm using a Fm1000 with a Pac Crest HPB radio configured as a rover receiving CMR+ from a Topcon base unlocked for Glonass and it seems to be using the Glonass satellites.If I turn off the rover radio and it reverts to autonomous it always has a couple more glonass sats than when set to rtk.I assumed this was because it only uses the sats that both rover and base receive a similar signal from.I guess I'm missing something but was happy thinking I'm able to use Glonass between different makes.
