SEQ, Australia | If you are running the FMX with internal GPS Receiver & Ag25, you will need the 75741 from Port C, the 67120 from the 8 pin end of the 75741, and the 12 pin end of the 67120 to the Ag252 cable sticking out of the roof of the tractor. The 252 will be disconnected and doing nothing.
If you are running the FMX and using the external GPS for RTK, you will need to put the adapter directly into the CNH NavII Harness, and plug in a 75407 to Port A or B on the FMX, the other end of the 75407 to the adapter, and leave the 252 connected to the cable sticking out through the roof. You will then go into the FMX/GPS/Setup and select External AgGPS receiver, and either Port A or B. The internal receiver on the FMX will then be doing nothing (because it is on Port C)
The modem will have to be hooked to the FMX if you are using the internal receiver, or hooked to the 252 if you are using the external receiver.
Edited by Trimbleguy 7/25/2014 07:48
