Clatonia, NE | Sounds like it could be signal, but I'm thinking you need to re auto-calibrate that thing. We've had a few GeoSteers do goofy things like excessive drifting and shifting some days and others it would be right on. Very frustrating to deal with. You might even start a new configuration, but I would start with a new Auto Cal first. Ag Leader should be able to help you with this if your dealer won't or can't. It's very easy procedure just get into the GeoSteer Settings and I believe the Auto Cal is on the first screen. Just follow the instructions after that. If that doesn't work, I would set up a new configuration and then auto calibrate. That is a little more involved and you might want to get Ag Leader or your dealer to help you. Good luck! | |
