| Tilt sensor keeps you online when the unit is tipped if you are going to use steering. Never tried without but doubt the system will even work without it. The tilt sensor is part of the steering system on these. If no steering there should be no problem.
It will paint the whole swath with one on you have to get into higher end systems with autoswath if you want boom control. The coverage mapping is a simple one wire connection that is either on Or off.
Edited by fourcubs 7/23/2014 06:50
