Cedar Rapids, Iowa | The NTRIP app says waiting for GGA from reciever.
If you configure the NTRIP app with a manual location, then it won't wait for a GGA sentence from the receiver. That will let it start streaming correction data.
It sounds like you're having an issue getting NMEA data out of the 500 when connected to an AutoPilot. I know you can get tilt-compensated NMEA data from the AutoPilot, but I'm pretty sure the correction data needs to go directly into the 500. Make sure the 500 will still accept correction data, then see if you can get NMEA data out of it at the same time. |
