NESD | I should have gave a few more details. When I have turned with the planter up my screen will show the coverage as though I planted it. When I lower the planter the clutches will not engage where the coverage is shown, the same as it would do if I had planted it. I'm not as knowledgeable as I should be about the whole system, my dealer hooked up the system, I ran the harness and installed clutches and sensors, but he hooked up modules and programed things. Yes, I have the clutch module and seed monitoring module if that's what it's called and a switchbox. We did check the normally open normally closed on the switches and I can't remember which it is but think it would only plant if hooked up the one way. Dealer thought problem was maybe in the programing but maybe we need to check the wiring closer. I need to learn more but scared it might be beyond my ability. Thanks tedbear. | |
