Posted 5/31/2014 10:00 (#3894815 - in reply to #3894718) Subject: RE: 4410 left boom won't spray. Aim command?
wisconsin
Swap the 4 pin battery power/ground connector from the master module to the slave and see if your problem goes to the other sections. if it does you have a bad splice between the battery and the modules.
