Posted 5/31/2014 08:07 (#3894685 - in reply to #3894665) Subject: RE: Magnum 245 3 pt. problem
Leeds, North Dakota
I believe so, hold diagnostic button and then turn key on and start tractor as your holding button, should get you into diagnostics, then use up down arrow to select 3 point calibration then select it, I am going from memory which doesn't mean a lot, you can't hurt anything, Scott.
