NC | I have recently purchased an airtec 3 pt. hitch sprayer and a Case puma 185. The boom movement functions are controlled by a joystick and a manifold with several solinoids for boom tilt,fold,etc. very similar to a Hardi machine. the problem I have run into is that the joystick must be mounted to an SCV LEVER which I do not have. I have switches to control the SCV's very similar to JD touchset. the joystick must be moved in conjunction with an SCV lever and a button on the joystick to activate the cylinders. has anyone else run into this problem on newer tractors and if so how did you overcome it? thanks
(2014-04-22 10.09.09.jpg)
Attachments ---------------- 2014-04-22 10.09.09.jpg (96KB - 211 downloads)
