Central MN | On my 1486 when I was plowing I needed to use the diff lock in one low spot. It worked great until the last few passes then I had smoke in the cab and the lights dimmed when I used it. The diff worked fine but just caused those problems. The switch was cold so I'm thinking it's wiring under the floor. I haven't tore into it but just wondering if this happened to anyone else. Thanks. | |
