Posted 4/28/2014 08:16 (#3840929 - in reply to #3840833) Subject: RE: Side dressing corn with a 2510H
Bethany, MO
You can to make your own. The only critical thing is the scraper has 2 little bumps in the slot that the rubber plug is in. It defines where the NH3 tube is located. The 2 tubes will have to split those bumps in the casting. Then you cut part of the rubber plug off with a razor knife.
