Morris, IL | So your just changing out the EPDM seal i call it, i will have to do that. I have a set of John Blue check valves for squeeze pump setup that i really like, Stainless steel ball with small spring, works very well so far. For at least 5-10 seconds i can see water (still only running water) flowing out of the flow gauges. I know 3' of liquid in that 1/4" OD hose has to drain out, i understand that but i'd think that would only take few seconds. I might try that tomorrow and see just how much of that 15 seconds of running is the 3'. With water in system pressure is only running little over 10psi, how much built up pressure can there be? This is a solid stream for 15 seconds then all a sudden it's gone. There is no way this is normal or guys would be talking about it all the time. 15 seconds is good part of my turn.
Edited by NEILFarmer 4/24/2014 22:08
