| What tractor is this on? I'd be interested to see where the display is placing the "triangle" that indicates the receiver location on the machine is actually at. If you zoom all the way in on the map you should be able to see this clearly. There has been a issue with this being place back towards the rear of the machine...which causes problems like this you are seeing, and when actually using swath control it was very hard to figure out at first until it was a known issue. This happens even when all the measurements are properly entered, checked, and double checked and leaves heads scratching. If you find this is your issue, simply toggle the box that selects which axle is the "fixed axle" on the machine from rear to front and then back to rear and it should place the receiver triangle back to its correct position. Hopes this helps. | |
