Posted 4/23/2014 06:47 (#3831451 - in reply to #3830885) Subject: RE: 2630 in 60 series combine?
Guelph Ontario Canada
Have you looked through the run page layouts to find the harvest ones? Software on the moisture sensor and the display may need to be updated. If I remember correctly the setup for the moisture sensor will always be in the brown box emulator but you should be able to display mapping and totals on the GS3.
