Up here we call jockeys scalpers.
The tractor has 5300 hrs. I had my local JD dealer do a back ground check on it before I bought it. That is how I found out it came from Missouri. He said that it was the original dash so supposedly that is actual? I personally think it has more but I guess I will never know. At some point they had to put new cylinder rams in the 3 point lift cylinders. So they must have done some heavy lifting at one point. The tires are set for narrow rows and they put them on backwards so it would give them more room to work on it. |
