Posted 4/9/2014 06:14 (#3805604 - in reply to #3805245) Subject: RE: Kinze 3600 Valve Block Pressure
thanks for your reply. not sure what you mean adding cartridge valves and solenoids, are they not already on the valve block? and if not what ports would we have to install them, can we take the ones from the markers? to do a test? we did hook into what we thought was the auxiliary ports ( V6 and V5 ) But got same result.
Thanks Jeff
