MN | Like others say, if she does the mowing, let her pick it out.
Now, I do the mowing and had a 48" JD tractor, took ~2 hours. Your mowing area is not very big and if you don't see that growing much you may not need a $8000 mower like many here are suggesting. I went to a JD z425, 48" a lightly used one can be had for under $3k. They are simple, NOT commercial, so don't plan on leveling gravel with it, and it cut my mowing time in about half literally. I have since upgraded to a 54" z445, it is an earlier model with the Kawasaki engine which I wanted and I also rented a farm that had a yard I have to mow, a lightly used one can be had for around $3k or so if you shop around. Again these are the yellow deck, "homeowner" models but they have worked great for me. I would love to get a 54" commercial version (green deck) but the price would be double and I just can't justify that-maybe that is not an issue for you. They do ride rough, but that is somewhat a by-product of speed, again if you spend ~$8000 you can get suspensions and suspension seats etc. I mowed 2 yards all year last year and only put about 70 hours on the 54" machine. | |
