ecmn | Wheat77 - 2/25/2014 20:10
That is how I see it. Unplug your block heater while running. Not sure why you would
leave it plugged in. Are some of you guys too fat and lazy ?
when its well below zero with a hard wind in 15 minutes after shutting off you would need to use ether if not plugged in. in the situation of the original poster I would simply leave it plugged in. not because i am lazy, but i am getting a little fat. for the jobs i have done over the last decade i can easily call you lazy and with the response you made i can easily call you an idiot but i wont. |
