| Yeah, we have an LM435A. Its been real good for us. It's used hard but it keeps going. We're probably getting close to 7000 hours on ours. We have had to do a fair amount of work on it but I think it's all things that would be considered normal wear items. Its hard to start if its real cold out and the hydraulics are abnormally slow when its cold. If you plug it in that helps it start pretty well though. The main complaint I would have is that the parts for it are ridiculously expensive. For instance, a tie-rod end is around $700. U-joints for the axle shafts are a little better than $200 a piece as I recall. | |
