fredericksburg, va | I mounted a backup camera/unloading camera beside the light on the unloading augar. works good. I ran the wire down the augar tube, came up behind the 4" wide rubber piece beside the cab and drilled a small hole in the plastic "vent" on the under side of the cab roof. went to the front of the vent then inside the cab. mounted the camera on the left cab post and power it off of the windsheild wiper motor and grounded it to the radio.(pos and neg leads need an extension). I used the camera off of the back page of a Shuop 2013 spring catalog. I used the cable that came with it and it was barel long enough. 18" shorter would not have worked. This is on a 9660 sts I do not know if its "long or short" augar but it about 10 feet past the back of the machine and tis HUR. Hope that helps! | |
