Posted 5/19/2013 18:45 (#3105890 - in reply to #3105496) Subject: RE: Hardi 361 pump?
Charles City. Iowa
Is the pump leaking out the bottom of pump? If is first check the diaphragms. Inside of the pump should be dry. Just grease no water. If there is water coming out of bottom of pump.you have bad diaphragm, lose bold, crack housing. We do have use pump parts too.
