Posted 5/10/2013 21:10 (#3091707) Subject: 8770 new holland
Ada minnesota
Planting corn today the 3 point started to act up. It raises real slow and doesn't all the way up. The code that flashes is f016 and the display doesn't match the 3 point height on the screen. Any thoughts thinking its a sensor but not sure
Posted 5/11/2013 00:52 (#3092045 - in reply to #3091707) Subject: Re: 8770 new holland
Northern CA
I had the sensor in the draft pin fail on my 8970. I think it was around $700 and there was no way to splice into the broken wire that broke at the base of the pin. I love the Genesis tractors, but the majority of our problems are with the 3 point. I am glad the only thing we do with the 3 point is plow.
Posted 5/11/2013 11:35 (#3092587 - in reply to #3091707) Subject: RE: 8770 new holland
ND
There was a post awile back where you could go into machine setup calibrations and disable the draft sensors, haven't had much luck with searches on here, will try again or somebody else will retrieve it for you.
