| Seeing how it's a TW I am assuming that you have power adjust inner wheels like most every TW I've seen. If that is the case the easiest way to go to 46" rims is to rip your cast centers off, try to find a pair of 10 bolt clamp on hubs and make something work. This isn't going to be easy because Ford really liked to use an 8 bolt clamp on hub which will do you no good and a huge ugly cast 10 bolt hub that clamps on with a wedge. The big cast one will only serve your purpose if you want to run it on 120" spacing. You can find a clamp on 10 bolt hub off of a later TW, I have only witnessed said hub on TW series II tractors and some early 8000 series. Went through this when we wanted to change my dad's TW10 to a different wheel and finally decided it was just fine the way it was. | |
