AgTalk Home | ||
banjo venturi inductor help Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
9550 |
NW Pa. | Just put on a 2" venturi inductor on my tender. Its very slow sucking the chemical down. I have the pump running full power. It take 10 min to pull 50gal? I do have 60' of hose on a reel. Appreciate some help thanks. | ||
Bugkiller |
what kind of pump you got on it? Horspower? The more head pressure you have slower it is. If your pump is undersized horspower wise it will be slow. | |||
9550 |
NW Pa. | 2" briggs 5.5hp. Pumps around 150 to 190 gal per min. | ||
thatsoliver |
sw iowa | I think the problem might be the 60 feet of hose after the inductor. | ||
wheaties |
Do you have pictures? It should suck 30 gallons out of an inductor in a minute or so. | |||
SDFarmboy |
You should just plumb your Chem. inductor ahead of your pump. No venturi needed, just close down the valve ahead of the pump, a little bit, and it will suck down 50 gallons of chem., in less than 20 seconds. I've been doing this for years, and now going to add another tank to recirculate and mix dry AMS, before the pump. | |||
9550 |
NW Pa. | Here's some pics (IMG_20130415_193119.jpg) (IMG_20130415_193218.jpg) (IMG_20130415_193135.jpg) (IMG_20130415_193156.jpg) Attachments ---------------- IMG_20130415_193119.jpg (63KB - 322 downloads) IMG_20130415_193218.jpg (55KB - 331 downloads) IMG_20130415_193135.jpg (48KB - 313 downloads) IMG_20130415_193156.jpg (57KB - 299 downloads) | ||
jedeka |
Boone, Iowa | Where do you have inductor? I have always mounted my inductors with a venturi after the pump. Current setup is two 2500 gal tanks feeding 5hp Honda motor/banjo pump, thru chemductor with venturi and out thru hose reel to the sprayer. Chemductor empties as fast as I can pour product in. | ||
9550 |
NW Pa. | Its after the pump. | ||
wheaties |
I think your venturi is backwards. Little end is on the feed side. Big end is discharge. | |||
jedeka |
Boone, Iowa | Cannot tell from pic but is arrow on Venturi pointing the direction you want flow to go? Looks like same chemductor/ Venturi as mine, but opposite direction. Could be assembled differently. | ||
RPTI |
Nebraska | I think venturi may b backwords | ||
jedeka |
Boone, Iowa | I just took pic of mine. Have to figure how to attach it. Edited by jedeka 4/15/2013 19:24 (image.jpg) Attachments ---------------- image.jpg (43KB - 302 downloads) | ||
9550 |
NW Pa. | We pulled it out of the box all put together. There's a sticker with a pointer for flow. I well try to swap the fittings around tomorrow. Thanks for all your help guys. Does anyone have a pic of one??? | ||
jedeka |
Boone, Iowa | I posted a pic of mine 5 post above this one. | ||
9550 |
NW Pa. | Jedeka, looks the same as mine small end after inductor tank going towards reel? | ||
wheaties |
I went and looked at mine, it is plumbed the same way. Were you shutting the valve on the other side of the venturi to make all the water pass through the venturi? Those work well and they will take a lot of product as fast as you can dump it in the funnel. | |||
1820-10 |
se montana | mine is the same as Jedeka picture also.. doesn't make since to me but been that way for years... you would think it would work better the other way but..... thats how it was labeled.. i never had to much trouble drawing out of inductor... however this year started with a new to us sprayer..it is a bottom fill, old sprayer was a side fill both summer's.... the bottom fill does not draw out of the inductor as well, and is harder to push water into 1500 gal. tank....wish they would have put a top fill port on top | ||
9550 |
NW Pa. | Yes the by pass valve is shut all the way. How much hose are you running wheaties? | ||
jedeka |
Boone, Iowa | Here are pics of my pump before inductor and hose reel after the inductor that is mounted below the trailer floor. I am filling 800 gal tank on Rogator without any problems. Had similar Venturi on a smaller chemductor tank that filled our old 1200 gal pull sprayer without problems. Edited by jedeka 4/15/2013 19:53 (image.jpg) (image.jpg) (image.jpg) Attachments ---------------- image.jpg (58KB - 305 downloads) image.jpg (58KB - 294 downloads) image.jpg (54KB - 311 downloads) | ||
CaseFarmer |
Flora IL | i agree... shorter the hose the better.. | ||
Crop Walker |
Central Ontario | I would pull the clamps off the Venturi and check for an obstruction. Had it happen once. | ||
wheaties |
I bet you have an obstruction, I don't run a reel, but I imagine my hose is 25 feet. I do not think length would matter. I am plumbed 3". I bet you have a rock or something in there. | |||
farmermatt |
West Central Missouri | There is a significant amount of friction loss in 60' of hose but I can't see it should take 10 minutes I've loaded over 70 gallon of product into a 750 gallon sprayer and still had to add more water | ||
cts backer |
35 miles south of Houston,TX | Here is a picture of mine (HPIM0739.jpg) Attachments ---------------- HPIM0739.jpg (55KB - 315 downloads) | ||
MTfarm |
Shelby, MT | Check for air leaks on fittings and hoses, etc. If it sucks any air it will be slow | ||
caleb_brown |
West KY | I would bet it is a plastic seal from the top of a jug stuck in the little hole in the bottom. I've seen that happen before. Another thing to think about is you have sharp angles pretty much right before and right after your eductor. Could be losing some pressure there, too. | ||
alafarmer |
I have two 3000 gal tanks on my trailor and dang I don't have near the fittings as you, but my mixing tank, don't know what an inductor is, but mine is in front of pump or teed into line going in to pump and it will empty 35 gal in a few seconds. | |||
BigDave |
SWMN | somebody's messin with you, sticker backwards | ||
robertbarlage |
Canada | Some sprayers filter before going into tank and if the screen mesh is to small it restricts to much and will cause venturi to suck slow . Easy way to find out is is you can just run pure water do not hook up to sprayer let run out ,fill chem handler with water and see how fast it sucks out should be very fast with no restriction | ||
Raylee77 |
East Central Kansas | +1 When my screen on the sprayer starts getting plugged, got a new old tank last year with some green growth in it, it won't pull from the inductor for nothing. Check your inlet screen. | ||
jedeka |
Boone, Iowa | Crop walker, looks like Banjos setup in their catalog. Did they get sticker on wrong too? Edited by jedeka 4/16/2013 08:44 (image.jpg) Attachments ---------------- image.jpg (28KB - 397 downloads) | ||
wheaties |
I have my venturi laying on its side with a manifold that feeds it from 4 chemical choices. Those are fast and efficient. Let us know what you find out. | |||
roadrunner |
If the narrow neck needs to go before inductor, then Banjo sticker is wrong in numbers I believe. Bought one at farm sale preassembled with arrow on venturi as first poster displayed. Didn't suck out so put ahead of pump to make it work. Tech at Banjo dumbfounded. Bought another on sale over winter and haven't tested yet | |||
(Delete cookies) | |
