Posted 4/4/2013 15:27 (#3012816 - in reply to #3012401) Subject: Re: Ether injector on tractor
Engine builders insist on the nozzle, NOT a can sprayed into the filter. Hook the power wire to the starter circuit, as recommended, and it will only function when the starter is engged. Just make sure the proper nozzle is used, and oriented correctly.
