Blvd d'Espair Bowhill, Sth Aust | Question about the metering clutch system on my manual drive 3450 air cart... But I think it's virtually the same on most F/C aircarts
When the individual bin switch on the Flexcontrol is thrown, does this give a short burst of power only, to energise the actuating arm solenoid briefly and retract the solenoid rod, which then stays retracted against the return spring in a detent position , until throwing the switch the other way gives an opposite burst which allows the rod to break free from the retracted detent position and the return spring encourages the solenoid rod to extend ?
I can't imagine there is constant power to keep the solenoid rod retracted because it would get extremely hot.
Edited by Ham 4/4/2013 03:18
