Wallis, TX | Lots of Taylor weights around here. Fit,,,,, OK, finish,,,,OK, paint,,,,,, OK. They are not quite up to the finsh of Case or JD but close. They normally have a few voids or sand showing from the casting and when you stack them up, they may vary a little (1/4" or so) across the top. i.e. 'the hook' where they hang on bracket may be a tiny bit off. But,,,,, they weigh the same and do the same job as factory. Don't know about Lonestar, never had a set of them. |
