Between Omaha and Des Moines, 7 miles South of I80 | John..neAR - 1/7/2013 20:35 OK, the jake even works when the truck is sitting still in neutral. Rev the engine with the accelator...let off and it instantly goes to idle. I mean no wind down whatsoever. I'll try all this again tomorrow, but I think there is a switch bad somewhere. Or maybe it is set to speed shift and I havn't learned the trick yet. >:) Thanks all, John
When I first read your complaint, I first thought about programming, OR how it is "set". I think you need to talk to an experienced mechanic or foreman for that engine model.
I have heard, about such programming, that they use the jakes to quickly lower engine RPMs, so a person could "Upshift" into the next higher gear, BEFORE you lose too much road speed, if climbing a big hill or mountain pass(but you still had enough accelaration that is was worth the upshift)
I've also heard, that if there was too much "rotating mass"; like a really heavy flywheel and clutch assembly, that the engineer's needed to activate the jakes/engine brakes to slow down that "mass" so a driver could upshift, BEFORE he lost too much road speed.(If an engine design/rotating mass didn't allow it to coast down, quickly enough, for "normal "shifting)
