Maryland | have the same setup as gtfinc except edgevac and hyd drive for the vr starter. The new tube sensors for this year hopefully will be better than the old ones. They were junk. Edgevac can be a pain because there is about a 6 foot delay between when you start rolling and when the seed drops. The insight taps into the FM750 I have for autosteer to get its signal. I thought the whole thing with ISOBUS is it is supposed to work with everything. But then again, do things always work like they are supposed to? | |
