Between Omaha and Des Moines, 7 miles South of I80 | I was thinking along the same lines as Luke. I was thinking about conversion rims to get to 46" also, OR Unverferth stub-disc wheels/rims to get to 46".
A taller tire, but narrow, should help get a little more tire/tread onto the ground. Plus it should help keep the tractor "more level". I will still have to measure, for clearance, from axle to cab fenders, to insure you still have clearance with the "possible" 380/90R46 tire. |
