Search Forums | Classifieds (6) | Skins | Language
Aaladin Hot Water Pressure washer
sbosmt
Posted 12/14/2012 00:40 (#2750779)
Subject: Aaladin Hot Water Pressure washer
SW Montana
Was thinking about getting a Hotsy pressure washer and a dealer here has a used (about 12 year old but not used last 6 years) Aaladin washer that is run off natural gas. They went through it all, rebuilt pump and ready to go. We have natural gas in our shop and it sounds like the way to go with not having to mess with fuel, anyone have any experience with the natural gas or aaladin washers? They want $2300 for it with new 125' of hose, 4 gpm and 1600 psi, will this setup work well?
jdflyer
Posted 12/14/2012 05:45 (#2750834 - in reply to #2750779)
Subject: Re: Aaladin Hot Water Pressure washer
Centralia, MO
I can't speak to the natural gas portion but I had bad luck with an Aaladin pressure washer. Mine was electric with a diesel burner. The burner was part of the problem but I had trouble with the electric motor which shredded out its bearings in only a couple hundred hours and I had to rebuild the pump. The guy that did the pump told me that the pump didn't like to have to suck up water and Aaladin had set it up so it suck water from a supply tank rather than just taking pressure straight from a hose. Later I had trouble with the electric control panel.
robhawk
Posted 12/14/2012 07:24 (#2750897 - in reply to #2750779)
Subject: RE: Aaladin Hot Water Pressure washer
Bristol, Wisconsin
We have had An Aladin natural gas for probably for 15 years never a problem I think Aladin is one of the best I would look at a new price also seems a little high for a used on we went to 4 gal at 4000 PSI about 5 years ago $4600.00 if want a good contact email. Rob
Illinois John
Posted 12/14/2012 08:14 (#2750976 - in reply to #2750779)
Crawford County, Robinson, Illinois
I had an aladan pressure washer on propane that I wish I still owned.  It worked excellently for the 8 or so years I owned it, and as far as I know, it still works well, it is not too far away from me, but I haven't visited it for several years.  Excellent equipment, only problem I had was with the electrical safety device.
Big Pig
Posted 12/14/2012 08:31 (#2751002 - in reply to #2750779)
West central IL
Still have an Aladin bout 15 yrs old with lp, motor went out many years ago because a mouse got in it and rebuilt the pump once, but no big problems other than that, gonna guess washing hog barns i put alot more hrs on it then u will in your shop. Good Machines
farmer3315
Posted 12/14/2012 10:42 (#2751216 - in reply to #2750779)
SE Mo
Had Aladdin (4gal/2400psi)for 12-15 years before the pump started getting weak. We just traded it for another Aladdin (5gal/3000psi). Very good washers IMO. Both of ours was electric with diesel burner
ndred
Posted 12/14/2012 14:39 (#2751514 - in reply to #2751216)
s nd
Bought a used aaladin that has been good to me. What pressure do we have to start being real careful with around newer stuff? Maybe ready to update. Five and three thousand might be a good fit.
Edited by ndred 12/14/2012 14:39
