Posted 12/4/2012 20:43 (#2733220 - in reply to #2732853) Subject: Re: Leveling no-till land
NW Ohio
we use a JD 510 disk ripper on wheat stubble and then land plane behind it. The thing is if you are going to use a plane or leveler you need to bury most of the trash. Then after leveling we either rip the ground again or use an in lnline or paratill. This method works good in our ground I don't know how it would work for you
