roaming | the Viper has some advantages, such as being able to do injection (Sidekick) if that's something you need.
The 700 runs a single product with no problems, and is easy to use, and will offer more flexibility if you're looking at any other red equipment. (i.e. you can take the 700 out of the Patriot and put it in a red combine or tractor, so you're not stuck with a display that you only use for a single season.) | |
