just a tish NE of central ND | What are there things to be aware of when overhauling a 855 engine?I'm thinking about doing mine myself right in the tractor frame. The bottom end should be fairly simple and I may have to get a experienced helper for setting the overhead. I'm looking for advise on special issues that may arise,certain ways to do things, ring alignment.....and wear points that may be overlooked such as ways to determine things that need fixing and general cautions......The fuel pump and injectors are low houred so I should get by with what I have with no repairs on them(3-400 hours)Not sure what I will find in the heads though as I don't think they were looked at in probably 6-7,000 hours. The cam has probably ? 1500 hours on it?So I think it may check out OK.....We will see.
Yes, I will get a shop manual for it before I start.
Can the 855 injectors be checked? MINE WERE REMANS and improved the engines starting, but sometimes I still question them if they are operating like they were designed to do.
Edited by School Of Hard Knock 12/1/2012 16:08
