Posted 12/1/2012 09:43 (#2726551 - in reply to #2726381) Subject: Re: Can a planter ran with FM 1000 be switched to Pro 700? TIA
roaming
Correct - the 700 will not operate the fertilizer cart. If you control everything through the 1000, you will need a manual fold box to fold/unfold the planter. If you use the 700, those functions are built-in (but you would have to have the 1000 to control the cart).
