WY, OK | Depends how good you want it to look. If you want it pretty leave the posts long and come back after attaching the panels and cut the tops flush and add bars to the gaps at the bottom. If you want function just make sure you get the ends attached first and bend the panel up as far as you can and weld. If it is a really bad rise you'll have to "scab" and weld the panel over the next one because they won't insert. We did a few of these a couple weeks back. | |
