Search Forums | Classifieds (173) | Skins | Language
Want to put Hyd Drives on old Kinze planter
bushed52
Posted 11/29/2012 19:45 (#2723908 - in reply to #2719571)
Subject: Re: Want to put Hyd Drives on old Kinze planter
NW Iowa
You should be able to do it for quite a bit less than some of the posters are quoting if you are handy. Find a Parker TB series hydraulic motor of the appropriate size. Control it with a Brand efc valve and a TeeJet 360 slot application rate sensor. Should be able to control it with the Integra if Precision's motors can be. Once you have done that much, for a little more than the cost of the extra motors, you can have section control. I have 4 sections of 3 rows, hydraulic variable rate controlled by Precision's Row Flow for a little over $1000 in parts, most from the Surplus Center and some off ebay. That does not include the cost for the Row Flow module itself.
