Posted 11/25/2012 17:55 (#2716479 - in reply to #2715343) Subject: RE: GREEN SEEKER thinking bout one
Moundridge, KS
It works well. Make sure to have N rich strips put out in the fall. I usually try to put a flat rate out first if I believe the rate changes are going to be large. Also have 3 sets of Tee Jet streaming nozzles. Usually can make compromise with rates using ground speed.
