Posted 11/21/2012 01:42 (#2708691 - in reply to #2707377) Subject: Re: 876 Versatile using coolant
Lone Wolf, Ok
Don't forget - the sleeves - you may be at the engine rebuild phase -- ours did this -- pinhole in about the center of the sleeve -- dependent on where the piston was sitting - determined if it dropped into the oil or just was burned inthe combustion chamber -- drove me nuts for a month looking before finally found coolant in the oil -- rebuild was easy --
