Posted 11/15/2012 08:06 (#2698259 - in reply to #2698105) Subject: RE: Edge display-direct command problem-HELP!!
For whatever reason, the conveyor is not responding as you have noted so the error message is appropriate.
The first thing I would do is to put the system in MANUAL mode and see if you can manually change the speed of the conveyor. My guess is that you probably won't be able to, this then may mean that the control valve is defective or possibly the wiring leading to it.
