SE Michigan | I can not comment on your lack of wanting two screens in the cab. That is a personal thing. I have 3 screens in my tractor. One is directly in front of me and the other two are off to the right side.
That said if you are wanting to proceed with out much added expense I would stay with the two screens and connect the present GPS you have to the Integra system that came with the planter.
If you insist on only having one screen you will have to find out what is needed to give you GPS and allow the Integra to also do your steering. If you go with the first choice for the first year you can then make changes next winter when time is not a pushing and you will have one year under you belt and may have a better idea of what you want to do and do it right the first time you make a change.
