Posted 11/12/2012 15:17 (#2693206 - in reply to #2692826) Subject: RE: Case 330 turbo seed bed prep.
East Central Ia
We are in rolling ground and are going to pull a harrow cart behind ours next spring. In rolling ground it will slide side to side enough that the rolling basket will miss a berm on the outside of the tool every now and then.
Otherwise we hit chisel plowed ground once in the spring and plant it. Like the job it does.
