Search Forums | Classifieds (127) | Skins | Language
Smartsteer 6.0 update
Amc4life
Posted 11/11/2012 17:25 (#2691329 - in reply to #2691207)
Subject: Re: Smartsteer 6.0 update
Butterfield, MN
If things are working well for you, I wouldn't do it. If you're seeing performance problems, it wouldn't be a bad idea. The update is on the Raven website, and depending on if you are hooked up through CAN or through the "Display" plug going to port A, you will need to run the update differently. There are some update instructions for each in there. Mainly, you just have to be careful when you select from the list of updates on the Cruizer II. One nice thing you'll get if you're hooked up through CAN is the new style of 3D calibration where it averages it out from two directions. You'll also want to make sure that you have the newest version of 3.0.1 Cruizer II software installed as well, might be a good idea to update that one first if you haven't already.
