Posted 11/12/2012 18:23 (#2693478 - in reply to #2692400) Subject: Re: 750 RTX Steering Aggressiveness
Wasaga Beach, On
I wouldn't suggest moving your antenna. If you adjust you angle per turn first, then your online aggressiveness you should be good. Did you install the system yourself? Make sure the foam roller has good contact with the steering wheel and it is not slipping
