East Central Indiana | When you look at your harvest map in APEX, right above the map there are several icons that will help you manipulate the map (like a + and - zoom button). There are a couple towards the right that look like a square with a pointer and an odd shape with a pointer. If you mouse over them they say "rectangle selection" and "polygon selection". Click on the polygon selection icon and then go down to your map and click around the field you don't want. Once you have the field you want to delete surrounded go back up to the icons and find the red X that says "Delete Points". That will delete every data point in the highlighted area. Don't delete if you want this data in a different farm name. That is another proceedure though (and more complicated). | |
