Clatonia, NE | I would put Rawson Drives on personally, but you could also get a PWM Motor Kit from Deere to put on that bar. I like Rawson because they are low flow, high torque, and quicker motors than PWM. The only positive on the PWM is that it has less moving parts and generally are more trouble free (Rawson has been pretty good also). The Rawson module and hydraulic drive module are different, so make sure you're dealer is involved when you order the drives. Make sure to get the jump start switch from Ag Leader if you go with the PWM Motor. It automatically comes with the Rawson kit. Good luck! | |
