| Have had this happen on 2 different display's both Edge's and the one had it happen on 2 field's , started harvesting field , left went to another farm then come back to finish and go to load the field to finish it and this is where you should ge the dialog box that's says the operation has been already performed in this crop year do you wan to add to last map or create new but don't even get that and when you finish loading the field the previuos map where the field was started is not there , has anyone else seen this , is it a firmware issue ? | |
