Inside end at the fingers ripped apart. 635 dollars. Anyone ever have a solid stub made to drive in and weld next to the bearing. Would you already know the inner and outer measurements of the tube.
Also was considdering if getting the flight extensions, and removing the fingers would work. I only run soybeans.
