| lately on this tractor, the flashers seem to blow their fuse regularly. when i turn the flasher rocker switch to middle position, flashers only, and i turn on the field lights, the field lights flash. i swapped out the interlock 20 amp relay behind seat with another and dosent seem to make much difference. is it the flasher switch, cause if the flasher switch is in middle position it should not allow the field lights to come on? isnt the field lights supposed to be slave to whatever that switch tells it?
TIA
Joe | |
