Posted 8/24/2012 21:50 (#2556980 - in reply to #2555731) Subject: Re: John Deere 7200 planter Conversion
Pennyrile, West Ky.
It should switch to the 6-36 with no problems, and if you remove the fertilizer opener mounting bar I'd say you could put some kinze pushers on it....except for the center where the transmission and lift master cylinder are located, you might could put a regular unit behind the transmission by using some longer parallel bars...good luck
